-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Bow Nav. lamp out (https://www.offshoreonly.com/forums/fountain/109542-bow-nav-lamp-out.html)
Ran-Dom 32 08-08-2005 11:46 AM
Bow Nav. lamp out
changed the bulb - still not working??? anyone have an idea how to access to wiring to it?? '99 35 - possible fuse blown??
BZ 08-08-2005 12:35 PM
Re: Bow Nav. lamp out
I could write a book on that silly light, I would take the mirror off at the head od the bed. you can get the wires easy that way. start there and if you have questions pm me for more I am on my 3rd light and tons of time replacing/messing with it....BZ
Wally 08-08-2005 01:22 PM
Before tearing appart the boat i would take a volt/ohm meter and check the wiring at the light. You can learn alot just from the wires. It can tell you if you have a bad ground or if theres no 12v+ Hell you may just have corroded contacts behind the light underneith. Another very common problem ive seen on boats was the switch. ALOT of boat companys use the spde connector splitters which tend to fall off sooner or later.
Downtown42 08-08-2005 01:35 PM
Mine broke quick too. Inside the anchor locker about 2-3ft to the rear the wire junction came un-plugged. That was it!!!
Ran-Dom 32 08-08-2005 01:49 PM
It appears there is no power @ the lamp(tester12v), bulb contacts look nice & clean, Look like I have to trace the wires back. -switch lights up on the dash & rear anchor light still works
Ran-Dom 32 08-08-2005 07:03 PM
Problem solved, the conection came apart, new conector & good to go, thanks for the help. :cool:
Downtown42 08-08-2005 08:53 PM
:cool:
US1 Fountain 08-08-2005 09:07 PM
Mine did same thing. reconnected and secured it better.
pullmytrigger 08-10-2005 10:55 AM
I had to take the pimp mirror out to fix the wiring.......its good now... doug
