Fountain Speaker Up Grade >
Old 11-17-2010 | 10:40 PM
  #31
eddie's Avatar
Originally Posted by Ran-Dom 32
looking at upgrading my system over the winter, nothing crazy, what's a good choice on speakers, (to replace the fountain mood lights) JL still one of the better 6.5's?
We have been having better results than the JL's with the Focal Polyglass CVX 165's I have a hook up on them if you are intersted let me know.
Here are the specs: http://www.crutchfield.com/s_091165C...focal+speakers
eddie is offline
Old 11-18-2010 | 05:15 AM
  #32
Originally Posted by jmoore1225
Barryb what did you use to open/close them? I see no latch, just curious really thinking about doing this to the doors under my bolsters!
I put some extremely good velcro all the way around the top of the door.
All you have to do is pull lightly on the top of the speaker and the velcro will start to release.
Not one time did the doors fall open on their own in 3 years. I know the velcro sounds funky, but it really works.
BarryB is offline
Old 11-18-2010 | 09:15 PM
  #33
Yamaha 225's Avatar
My 29 Fever had the Stereo Upgrade No 1. That means an amplifier and 4 speakers toghether with a wired remote under the drivers side panel. I put in a set of Audiobahn marine speakers where the mood lights were. It make rear passengers feel like they are on a concert. But the problem is that the position is higher so you don't hear the front speakers as much. I have also fittet 2 x 10" Infinity subs under the rear bench seat. They take some space, but I feel it is worth it. Also a MPX amp is fitted in front of the sink in the cabin. THROUGH bolted as I have never got a amp to stay in position with regular screws..... It plays very well, but I miss some more in the front area.
Also, where should I fit a TV?? I have thought about this for over four years, and I can't really decide where to put it!! The cas is that if I use the V-berth, the TV must be seen from the bed. Then it has to be mounted in front of the dashboard. BUT then again, if you sit in the bench sofa, you can't see it as it is right over your head... That have led me to the conclution that it have to be mounted at the position of the stereo. Then you can see it from both spots. But this seems like a very difficult place to have it mounted!! Any ideas on this one???
As for the wiring of the head unit, I have wired the cabin speakers to the head unit and the cockpit speakers to the amp. There is a "signal wire" from the head to the amp, and I have put a switch on this in order to shut off the "cockpit speakers' amp", to save a lot of power if I am inside the boat and I dont want people on the dock to hear music. Same goes for the subwoofer amp. I will also make a line in wire to the AUX connection frem the TV when that comes in. I will go for a TV with integrated DVD player.
Yamaha 225 is offline
Old 11-18-2010 | 10:19 PM
  #34
US1 Fountain's Avatar
Ginger or Mary Ann?
Originally Posted by Yamaha 225
..As for the wiring of the head unit, I have wired the cabin speakers to the head unit and the cockpit speakers to the amp. There is a "signal wire" from the head to the amp, and I have put a switch on this in order to shut off the "cockpit speakers' amp", to save a lot of power if I am inside the boat and I dont want people on the dock to hear music. Same goes for the subwoofer amp. I will also make a line in wire to the AUX connection frem the TV when that comes in. I will go for a TV with integrated DVD player.
I wired my stereo the the same way. I didn't want the cabin speakers to be on an amp for watching movies, so I just use the HU to power the speakers in the cabin. 4 speakers in there still rock to movies. I used a 6 pole switch..... to switch between the turn on wire for the amps in the cockpit speakers/subs, and also used 1 lead for each of the 4 cabin speaker to turn them off/on. This way I still have full control over fade/balance of both the cabin and cockpit.
My HU plays DVDs, so I use it as my player, with the video out going to my flatscreen. The TV is 12VDC, so I can watch movies out on the water if I want.
Mounted the TV where the mirror was. Made a box to surround the TV and to angle it a little for better viewing on both sides of the cabin. It's worked great for us. The mount was made to fit within the mirror mounting holes so I can change it back w/o having any holes from the TV mount.
I've since removed the additional front RCA jacks as that was before I mounted the TV and used them for when TV sat on the counter and simply plugged it into the Video out jack. The audio in jacks was for connecting the Ipod, but that has also been changed over to hardwired directly to the rear of the HU.
US1 Fountain is offline
Old 11-19-2010 | 09:47 PM
  #35
I am interested in the focals they sound superb but very pricey considering i need 5 sets of 6.5 Thanks
kickin32 is offline
Old 11-20-2010 | 01:28 AM
  #36
Kickin check out kickers.... I have all non marine in my boat, been washed, you name it!!! Everyone loves them....
jmoore1225 is offline
Old 11-29-2010 | 05:42 PM
  #37
Ran-Dom 32's Avatar
Originally Posted by gottafever
I also put a set of 6.5" mb quarts where the emblem lights were. You will have to make a trim ring and cover it with vinyl because the speakers are a little smaller in diameter than the emblem lights. I put 4 2-way 8" pioneers under the rear seat. To get more speakers in the cockpit, I removed the fold down access doors and replaced them with marine board cut out the same exact size to hold speakers. That way if I ever sell/upgrade I can take the speakers with me. I have two pair of MB quarts 6x9 up front where the front access doors were and two pair of 6.5 where the rear access doors were. I also have put a 12 sub up front where the mirror use to be.
anyone try to fit th JL 7.7's to in the emblem lights? My boat is in storage & I can't measure, thinking of running 4 JL's in the cockpit
Ran-Dom 32 is offline
Old 11-30-2010 | 11:45 AM
  #38
Bullhead's Avatar
Focals are worth the extra $.....call waves and wheels in LOTO...they are a large distributor for Focal and have excellent pricing
Bullhead is offline
Old 12-06-2010 | 10:48 PM
  #39
eddie's Avatar
I sent you the new prices, Bob just pulled 12 pairs out of a boat. It sold and the new owner didn't care for the look of 24 speakers in a 35 Outlaw. If you want to save a few bucks and used doesn't bother you let me know.
eddie is offline
Old 12-07-2010 | 01:15 PM
  #40
Ran-Dom 32's Avatar
pm me a price for 4 6.5's
