Small red dash indicator lights
Are they LED's or bulbs? Need to replace 1 of them. Just as soon have the same.
They are the flat lensed ones. Thanks |
Re: Small red dash indicator lights
They are sealed beams. I have them in stock, it's standard Livorsi part. Around $4 each.
Lofty,
Mine have the flat lenses and are made by SoLiCo, installed in 5/16" hole. Livorsi's say install in a 1/4" hole. Also shows them with a domed lens. This is the manufactures site. http://www.solico.com/solico_02.pdf Shows them available as LED or Incand. What I am trying to match.... Thanks |
You can get those straight from Fountain. I called looking for some white ones for my dash but all they have is chrome.
I'm going all new so i think i'm going to go with those solico ones. thanks for the link. |
Their home page lists their distributors, but might try the 800 number tommorrow anyways.
Did they give you a price? |
no, i'll try calling the 800 number, probably next week. i hope they're not too much, this new dash is already expensive enough as it is.
Those older switches like you have shown in pic #3 are also impossible to get too. The replacement switches are no match for the earlies ones. :mad:
http://www.mouser.com/index.cfm?hand...oductid=275046 heres the spec sheet on it: :) http://www.tycoelectronics.com/produ...s/W2331_DS.pdf |
Support your boat factory. :evilb: |
Originally Posted by Wally
Are they giving you different ones? or not making them like they used to Frank? cause i found them.....not cheap but still the same ones form the look of it :)
http://www.mouser.com/index.cfm?hand...oductid=275046] Yep, looks to be the same thing..... Potter/Brumfield |
| All times are GMT -5. The time now is 01:18 AM. |
