Sport Master Short Case -2 >
Old 02-09-2006 | 09:43 AM
Ran-Dom 32's Avatar
Default Re: Sport Master Short Case -2
3380 each?? complete bolt on??
Ran-Dom 32 is offline
Old 02-09-2006 | 11:27 AM
Thats the price I got for complete units.
$ 1,688 was case only
$ 600 for vertical shaft ( apparently, they use
a 2" short sportsmaster shaft)
lead time was 4 weeks.
JaayTeee is offline
Old 02-10-2006 | 04:24 AM
Nauti By Nature's Avatar
i'M LIKE TO KNOW IF THE BRAVO SHOP LOWERS WITH XR UPPERS WILL HOLD UP ON MY 38 FEVER WITH 650 BLOWER MOTORS .
THOSE B*MAX DRIVES LOOK QUITE SOLID THOUGH !
RATED AT 850HP USAGE , ANYONE USING THEM ?
WOULD LIKE FEEDBACK THANK YOU .
Nauti By Nature is offline
Old 02-10-2006 | 07:57 AM
Ran-Dom 32's Avatar
depending on what kind of a driver you are, I don't think you will have a problem with that set up.
Old 02-11-2006 | 10:07 PM
offshore conditions in NY NJ long island areas sometimes demand more from equipment , if the driver is up to it !
so when I am ready the equipment needs to be ready also ,
as ready as the driver I might be running against , to avoid mechanical breakdown .
Old 02-12-2006 | 01:56 PM
Strip Poker 388's Avatar
Rob
B Max
Attached Thumbnails Sport Master Short Case -2-b-max-lower_2.jpg   Sport Master Short Case -2-b-max-short-lower.jpg
Strip Poker 388 is offline
Old 02-15-2006 | 10:26 PM
Originally Posted by Strip Poker 388
B Max
Are those lowers built with xr gears ? and hardened steel
prop shaft?
Is there a updated version of the lowers coming out in near future ?
Old 02-15-2006 | 10:43 PM
B Max
That B-max on the right looks sharp.
Marginmn is offline
SPEEDTOOL
Drives and Lower Units
3
07-30-2008 11:42 AM
SPEEDTOOL
2
07-16-2007 08:43 PM
O-Limit37
02-03-2003 03:38 PM
Hot Boat
2
03-28-2002 01:52 PM
Goodfella
02-28-2002 10:15 PM
