-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   where to put depth sender (https://www.offshoreonly.com/forums/fountain/124953-where-put-depth-sender.html)
sleeper_dave 03-15-2006 11:18 AM
I redid my dash this year, and bought a new depthsounder for it. The old one didn't work at any speed anymore, it was mounted on the transom.
The new one has a through-hull transducer.
Where is the best place to mount it?
DollaBill 03-15-2006 11:54 AM
Re: where to put depth sender
good luck if it is stepped.
itilldo 03-15-2006 12:20 PM
Mine is in the access hole under the cabin step area. 04 29'
Rebel_Heart 03-15-2006 12:37 PM
I spent the $ to put one in a couple of years ago, and it never has worked. I don't think that it is getting a reading at all. Wish I hadn't wasted the money.
Downtown42 03-15-2006 03:11 PM
They wont work thru the hull unless you drill hole to mount flush to underneath hull. I'd pass on it as well. My 35 never worked.
US1 Fountain 03-15-2006 03:38 PM
Ditto! It takes up valueable dash space
sleeper_dave 03-15-2006 10:29 PM
my boat is a '91. no step.
is there coring in the bottom?
the boat's at the fiberglass shop right now. it's either a matter of paying him to make it work through the hull, or ordering an external transducer and having him install it.
i boat in shallow water all the time, and i'm getting kind of sick of using my GPS as a depthfinder
rackster 03-16-2006 06:56 AM
Mount it at least 10" off of the keel (center of vee), there is coring from the keel out 10". With no step, you should be ok mounting just about anywhere from the cabin step down back.
pullmytrigger 03-16-2006 11:04 AM
search this forum......theres a few threads on it.......I used the plastic bag/water method through the hull on my 29 non step......works fine when your off plane........doug
GOODT 03-16-2006 11:26 AM
Have mounted many here when was working for the dealer with no problems, just make sure you sand both surfaces and use a good two part epoxy !!!!!! :D :D
