engine puked! >
engine puked!
engine puked!
Old 04-16-2006 | 05:11 PM
GOODT's Avatar
Default Re: engine puked!
Originally Posted by 99fever27
I was towed back to the marina by a nice guy in a Bayliner.
THAT has to be embarresing, did you hide in the cabin????
check filters, timming then things get tougher but start there as stated already
temp was ok?
GOODT is offline
Old 04-16-2006 | 08:59 PM
Coil?
Back4More is offline
Old 04-16-2006 | 09:02 PM
99fever27's Avatar
[QUOTE=GOODT]THAT has to be embarresing, did you hide in the cabin????
Embarresing doesnt describe how I felt. After flying up and down the lake and probably pizzing everyone off, I was happy to see anyone come by to offer a tow. Nice guy though, wouldn't except any money. I didn't hide in the cabin but I assure you I was out of beer by the time we made it to my marina.
I'm going to do a complete service on the engine this weekend and start checking everything out with the little things first. Coil isnt one I thought of but the way it was cutting out it makes sense.
99fever27 is offline
Old 04-16-2006 | 09:04 PM
99fever27's Avatar
Originally Posted by 88Fountain
If your Matt, then it's me Aaron. We had a great time in Richmond. How have you been? It sure has been great weather for boating lately. We took our boat down to SML a couple of weeks ago. We'll have to hook up with you at the lake or on the river.
Hey Aaron yep thats me. Had a great time also..im surprised we actually won that pool game being so drunk! We should hook up on the water this summer, are you going to do the poker run on SMl or the Potomac?
Old 04-17-2006 | 07:55 AM
We aren't going to do either poker run this year, going to wait for our two boys to get a little older. We definatly need to hook up on the water. I can come out to look at your boat if you want any help with it.
88Fountain is offline
Old 04-17-2006 | 08:03 AM
Boomer 880's Avatar
When this happened to me, it was the ignition switch. Give the key a jiggle and see of it cuts out. Hope it is something simple!
Boomer 880 is offline
Old 04-17-2006 | 08:56 AM
The distributor should be tight. If it is lose I would definately reset your timing. Might want to check your fuel water seperator, is it possible you got bad gas, maybe has water in it.
Magic Medicine is offline
Old 04-17-2006 | 11:32 AM
I hate to hear about this stuff so early in the season. I hope it is a simple fix for you and it doesn’t keep you out of the water to long.
Deltarat is offline
Old 04-18-2006 | 12:39 PM
sleeper_dave's Avatar
Ethanol in the fuel?
Just got done reading the threads about ethanol. If you got stuck with some fuel that was tainted with ethanol, you might have gummed up the carbs / fuel filters.
sleeper_dave is offline
Old 04-18-2006 | 04:05 PM
First take a fuel sample, then verify whether or not you have good "spark", and timing. Then, if these are good, check compression. Check for the necessities. When you find a problem with one of these systems, then you can focus on repairing the problem. Start with the easiest to check and work to the hardest.
rackster is offline
