Triple application??????
how does your standard center engine setup on your exhaust tailpipes mount to the fiberglass????
Re: Triple application??????
a little clearer?
My buddies trip 42 is mounted just like the other motors. Just plain ol hard rubber exhaust hose. The long tailpipes with out the support seemed questionable to me, but he never had any problems with the center exhaust. Merc/Gil exhaust.
my old setup was CMI Big tubes, they came out above the swimplate form. I have switched to E-Tops, had to redrill the standard Bravo setup. The center tail pipes go on the outside of the rear engines....my question is how do the tailpipes mount to the fiberglass??? does that make any sense
Mine were pipes that went thru the transom and had a trim plate with an o-ring that slid over the tail and mounted to the transom. I now have pneumatic mufflers that mount directly to the fiberglass.
Does the center engine exhaust through four holes on the curved part of the hull below the platform?
yep, it has a flush 4" tube that leads to the other holes |
2 Attachment(s)
I had to look :D There is a flange on the inside of the transom. The pipe stops even with the hull inside the "molded platform" Its called using the boat as a muffler :D Its not bad when your moving but it does shake the boat when your at the dock.
the second picture is perfect!!!! so how does the stainless tube mount to the hull?
2 Attachment(s)
There is a pipe with a flange welded to it. The flange is screwed and sealed to the transom. The long pipe hooks to that with exhaust hose. I know its dirty, I'm still spring cleaning :rolleyes:
THANKS!!!!!!!!!!!!!!!that is what I needed to know.....i owe you a few drinks :drink: :drink:
Why do some Fountains with trips use the outside exhaust, and others line up all 6 tips in the transom?
thanks for that exhaust pics, as it helps us a lil wit our trip exhaust were tryin to fit in cig :D , we used to have the center engine pipes run between the rear engines riser and carb, but now are havin to urn the center like cool trips, but run the pipes out the side flush.
later models have tips, mine is a 91 so i am stuck with them on the side |
tom if ya want all 6 to run out the back in line i can show ya pics of how the cig was set up, it had a thinner beam than ur fountain so id think you could run it like that as well. we even still have the custom long dry pipes from the cmi center exhaust :D
holes are already drilled, thanks for the offer :cool: :cool:
| All times are GMT -5. The time now is 07:04 AM. |
