purple wire
redoing a dash i have a purple wire coming off the alarm does anyone know where it goes to wire is broke.the other alarm has the same wire that ties to a pink then to the ignition.the alarm is going off but i have not had time to check complete system meaning drive oil and the nomal stuff.any info is much appreciated
Re: purple wire
purple on mine is 12v switched; goes from the alternator to the ign. swtch to all the guages
Any Merc. manual will have the general diagram. The buzzers and alarms you'll have to trace. Bryan |
Re: purple wire
Re: purple wire
That puple wire should be switched power to the alarm. The other wire(s) from the alarm will go whatever corresponding sending unit. Go to the library and get a 1992 Mercruiser service manual. It will clear it right up. Good luck.
Bryan |
