Removing the cabin couches on a 38 Lightning >
Old 07-07-2006 | 09:40 AM
Default Removing the cabin couches on a 38 Lightning
How do you remove the lower and upper (back of) couches in these? One of mine came loose and has several long/short screws hanging from it. For the life of me, I cannot find how to reinstall. I am also reskinning both so need to know how to R/R these. Any help would be greatly appreciated.
Viaqua is offline
Old 07-07-2006 | 09:53 AM
29goingon42's Avatar
Default Re: Removing the cabin couches on a 38 Lightning
Call a Dr. Vinyl guy, they did mine at the dock for $150.00
That was worth the Monkey hassle for me at least
29goingon42 is offline
Old 07-09-2006 | 06:17 PM
Many thanks but do not have a Dr. Vinyl around here.
Viaqua is offline
Old 07-09-2006 | 11:18 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
The seat bottoms are screwed thru in the center pleat. Spread it open and look real close for signs of screws. Alot of times the screw head will be below the material.
More than likely only a couple screws on each.
Not sure on the backs.
US1 Fountain is offline
Old 07-10-2006 | 09:21 AM
Many thanks-will look between the cushion creases. ANYONE know how to remove the back cushion? I called Fountain cutomer service and as usual, no return call.
Viaqua is offline
Old 07-10-2006 | 10:29 AM
p4-33's Avatar
I pulled mine out of an older 10-Meter, dont' know how similar yours are.
In mine, there was a deck-access plate in front of the seat, where the inner hull support for the seat sits on. Mine has four of these, 2 per side. If you have these, pop the covers and you'll find nuts on the end of some LONG screws.
Also on mine, the bench back has arms on it that bolt thru the floor. Fasteners for the seat bottom and the back can be reached via the same access plate.
Good luck,
Brian
p4-33 is offline
Old 07-10-2006 | 03:47 PM
just simply look in the crease. You'll eventually find them!
wcmarine is offline
Old 07-10-2006 | 05:25 PM
Many thanks for all replies. I will look (BETTER) in the creases. As I expect, the screw heads are probably buried past the material in the creases but before I really tugged on something, I wanted to ask the Q cause generally I will tear something up the wrong way first.
Once again, thanks to all for responding.
Mark
Viaqua is offline
Old 07-11-2006 | 06:56 AM
BlondFountain's Avatar
Thanks for all the great info. everyone. We will also be re-doing ours soon.
All the info. REALLY helps.
BlondFountain is offline
onesickpantera
Prop Talk
13
08-25-2008 07:22 PM
Poorsche
10-22-2005 10:41 AM
Biggus
Cigarette
15
03-09-2005 08:33 PM
yzbert
Baja
2
02-07-2005 03:01 PM
alpine99
Fountain
6
02-03-2005 10:51 AM
