-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   water in bilge why? (https://www.offshoreonly.com/forums/fountain/134625-water-bilge-why.html)
sonic28 07-07-2006 08:31 PM
water in bilge why?
2004 35ex water still in bilge even after replacing all four diverter hoses.do all 35 exs have water?i wetdry all the water and after an hour or so the bilge pump goes on.so i know its when im running.i did block off the bilge outlets to see if the water was entering tru them nope.then i covered all the vents nope.still water.anyone
GOODT 07-07-2006 08:57 PM
Re: water in bilge why?
was a tech for local dealer for the last 6 yrs and the answer is no there should not be water in the bildge unless raining
Sea-Dated 07-07-2006 10:37 PM
My 1990 29 Fever does the same thing. I have tracked it down to where the exhaust tubes connect to the transom. I have not gotten back there to fix it yet but when it is running you can see water coming down the transom from the exhaust tubes.
29goingon42 07-08-2006 01:06 AM
Me 2... At higher rpm's I peeked under the hatch and I saw water leaking from the transom exhaust. Not alot but enough to make me :mad:
sellsman11 07-08-2006 01:07 PM
Lookout.....don't wanna pizz off the "Dirty Sanchez"
pachangalpina 07-09-2006 10:38 AM
Do you have closed cooling? If not, check the weep holes on the lower side of the engine circulating pump ( the automotive style pump).
Cash Bar 07-09-2006 12:57 PM
I had a 29' and guess where I found it coming from......... F'n WASHING IT !!! :mad:
Apparently Fountain does not seal the rubrail/joint screw holes or the bowrails. All the water from washing it down goes in there and sits til you take it out or move it, then flows to the back. Same when it rains..... :mad:
GOODT 07-09-2006 08:40 PM
they sould be sealed, we did have some that where leaking around the windshield........
oh a couple that leaked at the bow cleat
keep in mind that these boats are all hand built one by one and there main concern is SPEED these are not formulas, sonics ect where they build them all at porduction line type speeds, any where that hand build cars, boats ect there are gliches and thats where buying from a first class dealer makes a differance.....
when I used to work for the dealer I used to tell the customers up front to run the boat for a couple of weeks and make me a hit list of what needed to be addressed and then we would go over any problems they had I would tell them that there will be some things and all understood
Hot Duck 07-09-2006 11:11 PM
This may sound simple, but if you have sea strainers check to be sure that the tops are nice and tight and that the seals are in good shape. If the tops are not tight or if the seals are worn, water can come through between the top and the base while you are running due to the water pressure.
blownincome 07-10-2006 04:59 AM
If it has 496s check the bypass check valves on the bottom of the manafolds where the blow offs are for winterizing the motors they can leak also
US1 Fountain 07-10-2006 08:59 PM
Water coming in from running or just at rest? Pretty good leak for the pumps to come on only after an hour.
Mine was leaking at the rear rub rail. That area is impossible to glass from the inside like the rest of the boat is, so Fountain seals that joiunt with sealer, or at least they shoot some in there. Both my 27 and 32 leaked there. I cleaned out the sealer and filled with 5200. Now even my 32 never gets so much as a drop in the bilge. Quite a feat from the way it sits with the rub rail in the water.
Cooler drain into bilge?
Stoney 07-11-2006 06:46 AM
Just had my 2007 35EX serviced for a leak. Ventilation hose under the port motor was not sealed correctly at the thru hull fitting.
It only leaked while resting as this part of the hull is out of the water while running.
