power vs weight and speed question >
Old 07-08-2006 | 10:23 AM
Bad Girl's Avatar
Default power vs weight and speed question
anyone running big power in a 42 with a heavy hull? what props and speed do you run? my boat is 12k lbs with fuel. twin 900's. I am working on a prop selection. anyone have a close setup?
I know the standard factory boats tend to weigh 3000 lbs less than the race hull I have.
thanks for any input.
Ken
47 Lightning SE
Bad Girl is offline
Old 07-09-2006 | 07:18 PM
Default Re: power vs weight and speed question
There is 1994 obviously non stepped, 42 CS with twin 950's in the classified that runs a little north of 100 mph.
Fanatic is offline
Old 07-10-2006 | 09:54 AM
Bad Girl's Avatar
FANATIC, Thanks for the info.
47 Lightning SE
Bad Girl is offline
Old 07-10-2006 | 09:44 PM
I have a 2007 42' Lighting with Merc 850's with 6 blade Herring 37/17 top speed so far at fountain testing lake was 118mph ran 115 at Havasu last week at 5300 rpm. Hope this helps.
havasuhustler is offline
Old 07-11-2006 | 08:34 PM
Bad Girl's Avatar
Hav Hustler,
Do you know what your hull wieght is? Do you have a factory boat? thanks
BD
47 Lightning SE
Bad Girl is offline
Old 07-12-2006 | 11:17 AM
BD
My hull weight is 10,300 without fuel. I have a fully loaded cabin underneath..vac flush, refrig, flat screen/dvd not a race hull..
Old 07-18-2006 | 09:17 AM
Bad Girl's Avatar
Hav Hustler,
what gear ratio and drives are you running? what performance does the herrings provide than a merc 4 blade with ultra lab finish? thanks for the help
BD
47 Lightning SE
Bad Girl is offline
Wazzup Racing
OPA/The Jersey Boyz
21
03-27-2008 11:12 AM
Craney
06-27-2006 07:52 PM
Toffen
04-11-2004 01:26 PM
wildbill
6
12-30-2003 10:41 AM
wildbill
6
08-16-2002 05:57 PM
