prop or drive slipping >
Old 08-07-2006 | 02:54 AM
Post prop or drive slipping
I have a fountain 10 meter with 7.4 liter mercrusair engine driving trs drives thru borg-warner transmissions. The starboard engine and periodically the port engine will over-rev and loose thrust when I am returning home after a day on the water. It never occurs on the way out. But on the last two return trips, approx 3 hours later, I have had the problem. When i lower the engine speed, it seems to catch. Came home tonight only developing 12 mph, normally 50-70 mpoh. Any suggestions. Thanks in advance WB.
KNOTONCALL is offline
Old 08-07-2006 | 07:27 AM
Default Re: prop or drive slipping
Transmissions going out?
Enough 4 Play is offline
Old 08-07-2006 | 11:49 AM
Lofty's Avatar
Sounds like your trany is slipping. Pull them both out and freshen them up.
Lofty is offline
Old 08-13-2006 | 06:26 PM
carney's Avatar
before I pulled out the trannys and rebuilt them, I would look at and smell the oil if it is brown and smells burnt, then pull them. good luck.
carney is offline
smdude
08-18-2008 05:55 PM
copiercat
Drives and Lower Units
9
09-14-2007 09:22 AM
BAJA WILL
04-25-2005 05:55 PM
IHTFP
2
12-17-2002 11:56 AM
