-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   42 Fountain bottoms ? (https://www.offshoreonly.com/forums/fountain/139990-42-fountain-bottoms.html)
Strip Poker 388 09-08-2006 05:35 PM
What years did they change the bottom on a 42 from 2000 to 2004?
Downtown42 09-09-2006 04:38 PM
Re: 42 Fountain bottoms ?
Not sure but 2005 was a new bottom.
FeverMike 09-09-2006 09:45 PM
They went from the twin small steps to the larger steps around 2000. I believe the Fever still had the small steps and the Lightning had the new larger ones. Then there was a small change around 2003-04 and then again in 05.
FeverMike 09-10-2006 07:40 AM
Blume what did they use to call the 42 EX then? They had 2 different decks at one point. The 42 EX deck had the smaller steps then they discontinued that deck and bottom a year or so after they brought out the current Lightning deck and that hull had bigger steps. This was around 1999-2000.
FeverMike 09-10-2006 06:35 PM
Blume, in 1999 they built both decks but the new deck had the new larger steps for the bottom. There were a few of these boats -1999 models- at the Fountain dealer when I bought my 2000 29 Fever in Oct of 1999. I'll have to go look through some old Fountain catalogs I have. Confusing huh? :D
DirtyMoney 09-10-2006 07:26 PM
What was the bottom used around 95 was it just for one year? Small steps
FeverMike 09-10-2006 08:43 PM
rbr2328, No they used the small steps up till '99
44MTI 09-10-2006 11:01 PM
The smaller steps were a much more stable bottom at higher speeds.
Not to confuse the issue, but they had 2 different large step bottoms in 99 and forward, but with different angles of attack.One was for small power bravo boat and the other was for large power #6 boats. But there were mistakes, I ended up with 900SC's and #6's on a boat with the more aggresive bravo bottom. Ran great, but could be unstable in very smooth water at high speeds.Then they also made a third large step bottom that was actually only notches, no step, also around 2001.I think this one was a very limited production and was used mostly for race boats.However Jeaston from the board here ended up with one of these.Sooooooooooooooooooo, that makes 3 possible bottoms.
Cash Bar 09-10-2006 11:41 PM
Jeez, I thought you only knew stuff about boats built "hypothetically".... :rolleyes: :D
44MTI 09-11-2006 08:32 AM
Well, your right, that is my specialty. :evilb: :evilb:
