Thru hull water pickups........ >
Old 12-27-2006 | 09:17 AM
INDY27's Avatar
Default Thru hull water pickups........
I am rerigging my 99 35" with a pair of whippled 500 efi's and want to use offshore type water pickups, thru the the transom or the bottom. Has anybody ever used these and if so where did you put them?
Thanks!
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 12-27-2006 | 11:05 AM
jryan26's Avatar
Default Re: Thru hull water pickups........
Pics man, we need pics.
jryan26 is offline
Old 12-27-2006 | 11:25 AM
INDY27's Avatar
Patience Grasshoppa
INDY27 is offline
Old 12-28-2006 | 05:26 PM
Elite Marine's Avatar
Pictures please!!
I'm doing the same thing and would like to see what you've installed.
Elite Marine is offline
Old 12-29-2006 | 08:43 AM
INDY27's Avatar
getting the motors ready
INDY27 is offline
Old 12-30-2006 | 10:13 AM
Bad Girl's Avatar
I have thru hulls on my 42. they are located about 6" forward of the notch and may 4" from keel center. My boat is covered and will have to get in there for a picture.
My hull has a scooped duct the leads to the pickup carved into the bottom. They machined the scoop into a piece if aluminum and bonded it to the bottom of the floor where the bottom has the shaped hole in it to fit the scoop
The plate is 1" thick and 6"x6" and has the threads in it for screwing the pickup into it and for adjustment. I think mine is a bit extreme but I found the trailing edge of the pickup should hang down 1/8" to 3/16" below the running surface for correct pressure setting.
I will try to post a pic in a day or so.
One thing I have to control is flow rate and pressure to be sure the headers and tail pipes are full of water.
Ken
47 Lightning SE
Bad Girl is offline
Old 12-30-2006 | 10:26 AM
cougarman's Avatar
Will these work for you ?
Let me know......................There ready to ship I ONLY HAVE THREE OF THEM.
Also have the three latham's if any body is looking for them.
Cougarman
Attached Thumbnails Thru hull water pickups........-thruhull1.jpg   Thru hull water pickups........-thruhull2.jpg   Thru hull water pickups........-thruhullntransomepickups.jpg
cougarman is offline
Prater
7
09-09-2008 06:03 PM
QWKRN U
Eliminator
0
11-02-2007 10:53 PM
skydog
05-08-2007 12:43 PM
Leathl_WS6
Sutphen
0
07-11-2006 07:07 AM
khadley
Eliminator
3
01-25-2005 11:53 AM
