-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   amps, where are they? (https://www.offshoreonly.com/forums/fountain/150115-amps-where-they.html)
US1 Fountain 01-28-2007 10:34 PM
Re: amps, where are they?
Gott'm mounted up behind the bench seat back. Took some fabricating for a mount system to work, but got'r done.
Used 2 flat SS plates to mount each amp too and rolled the top edges over. (upside down J). And made 2 'J' plates that bolted to the bulkhead up high. Had to unbolt the trim pump panel to drill the mounting holes and bolt them on. Just lift the amps up inside the space and hook them on the J plates, then using 2 screws on the bottom to hold them down tight.
Should workout great. Can't see them unless you stick your head down in the seat, but still can adjust them w/o removing them.
