-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Prop Rotation on a 35 (https://www.offshoreonly.com/forums/fountain/150147-prop-rotation-35-a.html)
BobbyB 01-27-2007 11:52 AM
We are fixing up a 1993 35 Fountain. And forgot which way the props were rotating. Either both turning in or out? Does any one know the proper way the should be setup. I know a 96 35 with a step turns in. Thanks
Dkahnjob 01-27-2007 11:40 PM
Re: Prop Rotation on a 35
Hi Bobby,
I have a 2000 Lightning and the starboard drive turns left and the port drive turns right, so I guess you would say the both turn in. I think that is the fastest combination, if you have them going the other direction the boat is more manuverable for docking but not as fast.
David
RaggedEdge 01-28-2007 07:18 AM
I turn my 35 in, 99 single step, both with the Hydros and the Bravos. I would think even the non stepped hull would benefit from this. Some of the earlier designs came with the Mirage style props and I think they were turning out.
barron 01-28-2007 10:10 AM
I have a 93 35' turning in, seems to give more it transom lift.:cool:
35 fountain 01-28-2007 12:09 PM
04 35 ex - bravo 1X 32 pitch bravo 1 4 blades - mine turn in from the factory
Fenderjack 01-28-2007 03:28 PM
Turn them in, like said it will be a lil more tricky around the docks but will give ya more speed on the run..
Rebel_Heart 01-28-2007 07:54 PM
I have mine turned in. Sucks around the dock, but a little more on top.
US1 Fountain 01-28-2007 10:39 PM
I do more docking than a running WOT, so changed mine to turning out.
Figured if they were turning in, I'd just hit the docks faster. ;)
Sea-Dated 01-29-2007 08:15 AM
Mine are turning out from the factory. I like the being able to get the boat in a slip. Worth a mph or two when you are already as slow as I am.
blume 01-29-2007 11:13 AM
1993...............non-step, they all were turned out from the factory.
