running wires on a 35 from cabin to helm
Ok I am at a loss, I have been trying to run the wires from my radio in the cabin, to my remote by the side switch panel. I cannot find a place to run wires from one side of the cabin to the other side. My remote wire is not long enough to run all the way back to under the rear seat. Any hidden areas I don't know of.
i had to pull my windshield and when i did i un stapled the headliner and i saw some wire's going across only a guess on my part but it was easy to get to with the first row of staples out and was real easy to put back together!hope this helps.
I would guess it is the same setup as my 32. I run the wires over the cabin/cockpit divider panel (bulkhead?) where the bulkhead does not fully reach the underside of deck along the gunnel. (right behind the radio) Then drop the wires down inside that side storage compartments by the gas filler hose. Now the tricky part. If you use a flashlight and a mirror looking inside the storage compartment towards the front where the flooring stops and the gas hose goes down to the tank, you will notice using the mirror and light looking under the floor, there is a void all the way across under the floor from side to side. There is about a 3" space between the floor underneathe side and the gas tank. I ran all my speaker wires, Ipod wires and the 2 remotes wires going thru there. It's really a peice of cake and a straight shot IF your 35 is built the same as my 32. Takes just me a couple minutes to run them from the radio to the dash.
The wires come out in the drivers side storage compartment right under the wiring mess, right where you want them. |
Originally Posted by 35 White Lightning
(Post 2103741)
Good luck. |
My 06 35 has trim around the door that can be removed giving
acces from the radio> around the door and into the back of the dash. |
