Dash Help!!!
Hey guys I have a problem that is driving me crazy.WHen I bought my boat the old owner had an engine alarm on the starboard side go off for no reason.He said he checked everything but it would go on and off,so he disconnected it.Since I bought the boat I have a new engine with all new senders and a brand new engine wiring harnes.So I figure problem must be solved right.WRONG.Dam thing still goes off,has any one had a bad horn that maybe shorting out internally?I even checked the wire from engine to dash and it has continuity.I'm lost:mad: Now for my second question,I have two red lights just above my steering wheel,are they supposed to light when engine is running?and where should they be wired to?
1991 Fountain Fever Thanks for the help guys in advance. Nordic95 |
those red lights are warning lights. they are part of the alarm warning system, the visual part. they should light when they key of either engine is cycled. and only stay on when there is a problem. as for the alarm circuit, fountains use 1 alarm and trigger it v.i.a the tan with blue tracer wire from either engine. i have experienced issues of signal jumping before on the beaks, and is usually contributed to by faulty relays which control the alarm horn or corroded wiring. check the senders on the other enige as well.
good luck. |
Originally Posted by monstaaa
(Post 2111490)
good luck. Thanks Nordic95 |
if he disconected the alarm the lights would also be disabled
check your grounds also Bob |
Never forget the neutral saftey switch. Took me a long time to find that one.
F |
Originally Posted by nordic95
(Post 2111338)
But did you check the wire if it was also grounded? Shouldn't be, that's what triggers the alarm. I take it your alarm is the type with the buzzer and the small round timer as 1 unit, original '91 setup? The service manual has a check for that unit itself. Both my lights lit up whenever there was a problem with either motor side. I rewired and separated those lights so now they are for that motor only. Seemed only right. |
| All times are GMT -5. The time now is 06:57 PM. |
