-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Best Prop for 35 Executioneer (https://www.offshoreonly.com/forums/fountain/159261-best-prop-35-executioneer.html)
Rebel_Heart 05-25-2007 11:24 PM
I had been running Hydromotives prior to going to -2 Imco shorties. I am now breaking in the new lowers with some Bravos. I am seriously thinking of labbing some Bravos. for my final set up. Is there any other prop worth trying for top end? Herrings - worth the $? I am thinking that I should stay with a 4 blade for top end and the easiest on the drives? Thanks.
ACTIVESHACK 05-26-2007 10:31 AM
I ran 32 pitch labbed Maximus on my 05 Ex. It had 1.65 gears in the lowers. They were great getting on plane and ran 61-62 at 4000. The fuel economy was much better than with the 4 blades because of the better cruise speed.
Rebel_Heart 05-26-2007 11:09 AM
I'm only running a stock Bravo One uppers. I'm afraid of the five blades and the load they create. My gears are 1.5:1. Is the Herring or a cnc prop worth the extra money, or is a labbed Bravo One going to be the best. I need to be able to get on plane with my -2 shorties, but am looking for top speed. Really don't do that much cruising.
monstaaa 05-26-2007 09:02 PM
bets hole shot from the maximus and rough water/ allaround handling. and if you lad em they ll still give you the top end. and i wouldnt sweat the load factor ass your not making big power.
merc 4 bld and hydro p5 are about the same top end, p5 having more in the middle.
RaggedEdge 05-26-2007 10:38 PM
Hydro P5 or P5X?
monstaaa 05-27-2007 06:41 AM
p5, the p5 x's seem to work better on the singles.
i also have a set on a 38 that runs just under 110. i do like these wheels. the bite hartd, turn well, accelerate without losing top end. and are not so easy to ding up compared to some others.
HPFountain 05-27-2007 07:00 AM
I recommend labbed Maximus. Have had great success with them. Don't forget to cut the difuser ring down at least .5 inch. Make sure prop has cup also.
- Vinnie
monstaaa 05-27-2007 08:40 AM
- Vinnie
or what he said.
Rebel_Heart 05-27-2007 11:58 AM
How much do you think I would be giving up on top with the Maximus versus the Bravo? I have been speaking with Bblades. I am running 700hp per side.
monstaaa 05-27-2007 02:13 PM
99' 38 fever, 750 h.p, 1:50, 2" shorty, 15 1/4x30 max=100
" same stuff "4 bld merc 14 1/4x32= 104
rpm diff of 200, samr water conditons and air temps.
testing was done back to back to back along with hydro's 6 blds( they didnt work at all). what you sacrifice on top you will pick up in the midrange. before the lad expect 7-11 mph increase on cruise and 3 off up top. serious planing times . hammer down maybe 5 seconds vs. 20+.
HYDRO 5 BLD'S loose out the hole next to the max but faster.
Rebel_Heart 05-28-2007 12:39 AM
Great real world testing. I appreciate you sharing your experience.
What was the fastest prop that you tested? Sound like the maximus is the best all around prop. Is the Hydro 5 blade as fast as a labbed Bravo? If I read your post correctly, 104 for a labbed Bravo, 100 for a labbed maximus. You were running some good speeds! Was your shorty from Imco? Thanks.
monstaaa 05-28-2007 07:07 AM
on this particular 38 the p5's were faster. and yes they were imcos. the merc's were the fastest, but by far the max was the best all around. then the p5 as it was fast as well , then lab 4bld as it was hard to plane with the shorties and had no cruise and wasnt as stable during high speed ocean runs. but it was fast, and it took alot of tweaking to make it just right for that hull, not just a general labing.
H2Xmark 05-28-2007 10:12 AM
i have 4 blade hydro 29's on my boat labbed by throttle up, it has stelling boxes set at the highest setting and have trouble getting on plane in rough water, have to baby it to get up. I would look hard at the new cnc 4 blades that matt has now at throttle up, most 5 blade props are slower [top speed]than 4 blade props unless you have to much slip with the 4 blade
monstaaa 05-28-2007 10:41 AM
the 4 bld hydro is one of the least efficient props for planing and cruising on the market. it is only good for a paded or notched bottom for speed.
5 's are typicaly slower however their slipage is much better , thus giving you back your speed .
their is no substitution for trial.
all tests done , were back to back,and in triangle formation . as to go with , against, and across current and wind.
herring 5 &6, merc 4&5, hydro 4,5,&6, spinelli, done my herring, merc, throttle up, b blades, and my favorite long island propeller.
opinions are like a#$holes, everyone has one. i would borrow as many props as you can. use the info other boaters here have given. apply. then conclude for yourself. be thorough and document everything and you will find your BEST props.
good luck
Rebel_Heart 05-28-2007 11:59 AM
Have you tried the new cnc props from Throttle Up on your Fountain, or know of anyone that has? How would they be different from the Bravos or Hydromotive 4-blades? Would like to talk to someone that has tried the cnc'ed props? Thanks.
H2Xmark 05-28-2007 12:51 PM
there are a few racers that use the cnc throttle up props, each blade on a cnc prop is a mirror image of the other blade, unlike a normal prop. I have not tried them on my boat, i would like to. if you wont top speed and are not worried about mid range, or getting on plane the hydro 4 blade turning in on a fountain is hard to beat for the money
monstaaa 05-29-2007 09:56 PM
they do sound good, and they must be new pieces from hydro. i wouldnt mind hearing some input on em or heck even trying em out.
