-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   575's in a 38 (https://www.offshoreonly.com/forums/fountain/161117-575s-38-a.html)
monstaaa 06-18-2007 06:33 PM
Originally Posted by jryan26 (Post 2166292)
We know this! :D
aweee,, you so SSSSSillyyyyyy
monstaaa 06-18-2007 06:35 PM
Originally Posted by Viaqua (Post 2166569)
Agreed to the nth degree about throttling. It is by far the key to proper drive integrity and I can throttle well. We all can catch the errant wave though but I want the beef. The XR/ merc/imco shorties makes a lot of sense as they are plentiful and appreciate the B max input AND I already have the HP gimbals. Running buddy has a 2001 staggered 42' L'ing/575's, Eikert heads, proper remapped/dyno'd 575's at 725 h.p.( I can use his mapping), preoiler, Strainers, B max's with Imco shorties/dry tipped and although he is still looking for the right prop setup, after a lot of mistakes he has it dialed in. I will go with the XR combo then and get the heads done the same. So many thanks for your input-it means a ton to me.
Mark
so long as you can pass an o.l,,,,,,,,,,,,,,,,,
and thankyou, and you are welcome..
