-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   38 Lightning w/ 900,s ?? (https://www.offshoreonly.com/forums/fountain/163038-38-lightning-w-900-s.html)
rclaws35 07-09-2007 09:26 PM
01 38' Lightning with 900's and Imco's .Need to know what it needs for props. I have 5 blade Herings (32) but it does not get on plane very good but has great cruise speed.I have run it up to 5200 rpms 102mph.I have tried 4 blade Bravos (33 labs) and gets on plane a little better 5700 rpms @102 mph. I just think there is somthing better to do. The Imcos are 2" shorties with 2'' spacers and 1:50 gears. ANY SUGGESTIONS.
Marginmn 07-09-2007 10:25 PM
Try a set of PX5's or a set of cut down Maxims.
Downtown42 07-10-2007 09:50 AM
you should be min 110 with 900's
Rebel_Heart 07-10-2007 01:41 PM
As suggested, my 35 likes the P5Xs with the Imco -2 shorties. I would imagine a labbed Maximus would also be good.
rclaws35 07-10-2007 08:29 PM
How do PX5 compair to Herings ? ( as far as pitch size ) Anybody running a 2001 38 with 2" shorties ?
monstaaa 07-10-2007 08:44 PM
you should try a set of max's.32's without the spacers. or a set of 33 p5's.
for 900 h.p your speed is off. 00 38, 720, 1:50, -2 shorties,lab 32 4 bld merc, 6000 rpm = 104.
i bet you pick up big time with out the spacer's, and the max's will help planing issues .
you may even consider going to a 1:36 gear to up the prop speed, and will also broaden your prop selection.
with your power you should running at least 110/ 115.
rclaws35 07-10-2007 08:54 PM
Thanks for the info. Last year the ---- thing would not even get on plane with with the spacers off. It had around 800 hp then. We dyno these engines so I would know what I have. Anybody have 32 Max's ?
monstaaa 07-12-2007 01:33 PM
we do
rclaws35 07-16-2007 04:33 PM
Are they FOR SALE ?
monstaaa 07-16-2007 07:37 PM
i ll check in the morning.
