hey bro's doin't forget about me. she may be little buy she is a cc . and 55 mph
Originally Posted by fountain1fan
(Post 2228057)
THANKS so very much for the offer guys....Let me ask you all a question.
Are any of you running overhub props or are all of you running full can Ster Drive props? I would really be interested in what all of you are running. Dependant on the outcome it may require another full set of molds. I would appreciate the feed back guys! Thanks in advance! Julie |
Originally Posted by confused
(Post 2229280)
Originally Posted by throttleup
(Post 2229404)
Are any of you running overhub props or are all of you running full can Ster Drive props? I would really be interested in what all of you are running. Dependant on the outcome it may require another full set of molds. I would appreciate the feed back guys! Thanks in advance! Julie Julie, what is an ove the hub prop? What does it look like compared to the Bravo 1 26p's I am running? |
Originally Posted by marylandmark
(Post 2229433)
If you explain it- I doubt I would understand anyway...
So- I use regular props- like a B1- with the large shaft (XR?) hub kit. My exhaust flows down there some where until I get on plane and then it re-routes and shoots out the rear of the motor. Sounds awesome when it happens- right about when I get on plane it switches and "winds up" and off I go! Julie |
1 Attachment(s)
(Post 2229433)
The propeller is the center is the Medium size can for smaller gear cases for outboards. This propeller is typically seen in a 14.25-14.50 diameter props.
The propeller on the left is the OverHub Propeller and the propeller on the right is the Stern Drive propeller. Julie Julie |
Ahhh....got it thanks, Julie!
Went out on one on Friday and went 73.3 on GPS. Very cool and comfortable boat with a great ride.
| All times are GMT -5. The time now is 11:53 AM. |
