big cubic inch motors >
Old 08-13-2007 | 11:23 AM
bcfountain's Avatar
Registered User
Default big cubic inch motors
any of you fountain guys have any thoughts on big cubic motors?thinking about building a 572,or a 605 motor.i have a 502mpi now....great gas millage,just want something w/more snap.how do big engines fair on marine applacations?are they reliable?are they big and thristy?i know speed cost.....how fast do ya want to go...right.just looking around for the all the way around package.thanks.
bcfountain is offline
Old 08-13-2007 | 12:02 PM
Rebel_Heart's Avatar
You can easily turn those 502s into 540s. I had a dart block in my 27 that was 572. Currently, have 540s. They both dynoed about the same. You will definitely lose efficiency, but then again you can't compare the power gains.
Rebel_Heart is offline
Old 08-13-2007 | 01:21 PM
"there is no replacement for displacement"
gofastlvr is offline
Old 08-13-2007 | 07:37 PM
Beak Boater's Avatar
Charter Member # 545
If you are looking for seat of the pants acceleration, theirs nothing like blowers. Big cubic in. is nice, but smaller 540, with 7 lbs of boost, especially Whipple, or Prochargers, make up for alot of cubic inches. Had 540's with Whipples, had 572's with 1071 BDS blowers. If they are set up right, they can be as reliable as big cube n/a motors. Its a matter of preference. They are all had on Bravo drives
Beak Boater is offline
Old 08-13-2007 | 09:07 PM
id say a 502 block with 420 b&m blowers that is what i have on imcos in a fountain
fountainguy214 is offline
Old 08-13-2007 | 09:11 PM
YES, YES, and YES
jeff1000man is offline
Old 08-13-2007 | 09:16 PM
I have a set of 9.8 deck 582's. They are friggin awesome.
I don't have them built to their potential at all. You can easily make an 850hp na engine with those.
I even idle mine at around 600-700 rpms at the dock in gear.
Mine are set up and dynoed at 600 at 4500.
If you don't like blowers. Tunnel rams work really well in big cubic inch engines.
Talk to Scott at Dyno Flo. He is very helpful and you can't beat his pricing.
Old 08-13-2007 | 09:30 PM
tblrklakemo's Avatar
SeaRay Sundancer
first things first......getcha some serious drives so you can take advantage of the newfound power.
tblrklakemo is offline
Old 08-13-2007 | 09:37 PM
Underprop them a litle and let them spin. Take it easy out of the whole.
We have a guy here running a 36' cat with 900+ engines with stock old style Bravo's.
His trick is to let them slip a little. He stopped having luck above 6800 rpm's becasue of bad harmonics, but he does real good with them under or right at 6000.
The key is he has a lot of extra power that he doesn't use.
Old 08-14-2007 | 02:17 PM
stop fooling around and go T U R B I N epower.
GCAT911 is offline
Strip Poker 388
02-11-2007 09:25 PM
ratman
07-26-2006 08:43 PM
GPM
19
02-12-2005 08:08 PM
SinkorSwim
28
12-11-2003 11:38 AM
Ratchet
11-16-2002 04:20 PM
