-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Vibration/ On @ Off Plan (https://www.offshoreonly.com/forums/fountain/168898-vibration-%40-off-plan.html)
scottsumrall 09-17-2007 08:28 AM
Question, I have a small amount of vibration at 1500-2000 RPM when coming on and off of plan. Is this the props or something else. Also this is no vibration at any other time. 42 fountain staggered 525sc/ bravo 28 props. Thanks in advance. Scott
Single With Twins 09-17-2007 11:46 AM
Could be the four blade props, mine did the same with four blade hydros and is now gone with the five blades. Sorry for lack of detail but vibration is no longer and that is the only difference with the boat................
Carder 09-17-2007 01:10 PM
Scott, my 35 shakes a little getting on plane at same RPM. With smaller props it would blow out frequently, and I would have to attempt to get on plane all over again. I believe it is cavitation, or "bullet slip" when this occurs. (the props seem to be slipping, than hooking up, over again until on plane.
I have found using tabs to get on plane eliminates it. Carder
later 09-17-2007 01:20 PM
My 42 would have prop chadder(viabration) betwwen 1500-2200 when i had hydromotives on it switched to bravo one and went away all together.
later
scottsumrall 09-17-2007 01:33 PM
later
Later, I'am using bravo props now. Maybe vibration is not the correct term, it more like a shutter or a chadder. It's really no big deal I just wanted to make sure it was not something wrong with the drives or gimble housing. thanks again scott
razor1115 09-17-2007 02:52 PM
My 35 with four blade Bravos does that, too. Thought maybe might be having a gimble bearing issue, but no problems. Sounds like maybe something to do with the Fountain bottoms?? Happening with different props on different size boat... mine does it with tabs, too. Have noticed if I throttle through it a little faster, it's not as prevalent. But I also don't want to overload the drives while baby-ing it up...
Zack
MOBILEMERCMAN 09-17-2007 02:58 PM
Props are ventilating. Air is passing under the boat and making the props slip.
Jim
GCAT911 09-17-2007 04:19 PM
My 35 does the same thing. however, the vib is more
pronounced when fat on fuel. The lighter the fuel load
the lesser the vib
US1 Fountain 09-17-2007 05:31 PM
My 32 does same thing getting on plane. Hydro 4 blades.
Happens right after I get up on top and 1/2 way of getting the tabs up.
Never noticed coming off plane.
Rebel_Heart 09-17-2007 10:07 PM
I used to get the vibration all the time when getting on plane when I was running Quad 4s from Hydro. With the 5 blades, not shaking now - it just connects.
