-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Info needed on 94 32 fever with 415s (https://www.offshoreonly.com/forums/fountain/173662-info-needed-94-32-fever-415s.html)
Formula311-SR1 11-20-2007 01:32 PM
Looking at a 94 Fever with 415s.
Anything special to check out before a survey.
How does the non step compare to the early 95 and 96 step hulls?
What kind of speeds with stock 415s
FeverMike 11-20-2007 07:44 PM
The Merc 502 Mag 415hp were notorious for water reversion. I would have the risers removed and look for traces of water. Better yet remove a exhaust manifold and look up the exhaust port and see if the valve stems are coroded. As far as the boat goes as always have a full survey done and check for rotted wood on the transon and stringers. If the engines and props are healthy you might see low 70's
