-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Tab indicator adjustment (https://www.offshoreonly.com/forums/fountain/182088-tab-indicator-adjustment.html)
35 fountain 03-13-2008 09:38 PM
My right hand tab indicator is wearing off the finish on the dash panel. Seems like the little plastic slider is pulled to tight to the dash and over time it has worn off some of the red on the panel. Is there an adjustment to the indicators that would push the slider off the dash panel just a little?
US1 Fountain 03-13-2008 10:07 PM
No adj. Just a pointer screwed to an alum bar. Might try to put a small spacer under the pointer to move it out a hair. But that may just make it flop around a bit more. Or cut the foam padding down a hair to relieve some of the tension.
monstaaa 03-18-2008 08:01 PM
replace the plastic pointers. they should be shouldered to help avoid this. fountain has them in stock.
35 fountain 03-19-2008 08:34 PM
Thank you!!!
monstaaa 03-20-2008 12:02 PM
ju godit meng.
