Dead Battery - How to Open Hatch? >
Old 05-12-2008 | 07:38 AM
Airpacker's Avatar
A little special tool that costs about 2 bucks can take care of that problem. All you need is a cig lighter power adapter and two gator clips. Plug the adapter into a lighter/power outlet and hook the clips to the battery. BTDT.
Airpacker is offline
Old 05-12-2008 | 07:45 AM
Originally Posted by sleeper_dave
I just remove the bolt from the top of the ram in the fall.
How else can you disconnect both batteries?
MOBILEMERCMAN is offline
Old 05-12-2008 | 10:01 AM
10x's Avatar
10x
10x
I usually take off the front side vent, and reach down to the battery and hook up the cables from my bat charger direct to the battery. Don't know if that's possible for you to do.
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
10x is offline
Old 11-19-2008 | 12:01 PM
From: HILLSBOROUGH, NJ OCEAN BEACH, NJ & LIDO KEY FLORIDA
Default Slotted Sleeve
Txriverra2001,
Did You Ever Find Out Who Makes This Actuator Slleve That Allows You To Lift Several Inches ?
BUGSY is offline
Old 12-01-2008 | 02:39 PM
Bill Watson's Avatar
Smile
All you have to do is remove the switch plate that controls the hatch and using a jump-pac with clips or pins connect to the wires on the switch till you hit the right ones and the hatch operates.
Bill Watson is offline
Old 12-01-2008 | 03:50 PM
You can plug in the external jumper cables and use a separate battery charger hooked to the cable on 15 amps even with stone dead batteries. Sorry too late to help but it may help if it happens again.
pookie is offline
Old 05-07-2009 | 10:56 AM
We had the same problem with our batteries and external charger under the rear seat. We hooked up the shore power cord and then used a portable battery charger. It barely was enough power to lift the hatches, but it worked. The batteries were so dead we ended up getting two new ones.
fountainwidow is offline
Old 05-07-2009 | 07:33 PM
Yes Dave...I do the same thing, just in case!!!!
JayFan is offline
Old 05-07-2009 | 08:13 PM
kr1276's Avatar
I use a portable battery pack with a cigarette lighter plug and I plug it into the cigarette lighter. Then see if you can get someone to lift on it while pushing hatch lift switch.
kr1276 is offline
Old 05-07-2009 | 09:16 PM
I like that idea...
Back4More is offline
