-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Fuel consumption of a a 32 fever? (https://www.offshoreonly.com/forums/fountain/194087-fuel-consumption-32-fever.html)
jmoore1225 08-27-2008 05:41 PM
hey guys could you give n estimated fuel consumption an hour for a 32 fever w/ twin 502 efi's thanx
Dkahnjob 08-27-2008 10:56 PM
Well, sort of. I have a 35 single step with twin HP500EFI's.
I have carefully watched and logged fuel consumption.
Cruising at 3000-3500rpm (45-55 mph) I burn about 20-24 gph and that figures to 1.09 nautical miles per gallon or 1.25 statute miles per gallon. These numbers are off my garmin gps and actual fuel pumped into the tanks at fill up.
Hope this helps.
David
jmoore1225 08-28-2008 01:29 AM
good enough my dad was tryin to say he read that my boat would burn about 50 to 55 gph, I thought that was quite high. I know the stepped hulls are more efficent but can't see it being twice as much fuel with smaller power n boat then yours, thanx for the info
convincor253 08-28-2008 08:42 AM
My 1998 single step 32 Fever w/ stock 502/415's will get 1.63 mpg at about 3200 rpm's. I measured that over an 85 mile run. We were running in the low 50 mph range. Running at poker run speeds we get a little over 1.0 mpg. I run lab finished Bravo 30 pitch props. Hope that helps.
bob_t 08-30-2008 09:57 PM
WOT, a pair of 415hp 502 mags should burn right at 60-65 gallons per hour, combined. A pair of 500EFI's burn right at 80 gph, combined. Those are the numbers I saw in some of my older Powerboat and Boating magazines. For the 500EFI's in a 35 Lightning, that works out to be just over 1 mile per gallon at WOT. :D
PARADISE ISLAND 08-31-2008 07:18 PM
A 32' with 502's I whould guess 60 gallons per hour 5000 rpm :boat:I wonder about the 496's in a 35':rolleyes:
jmoore1225 09-01-2008 05:06 PM
how big a tank does the 32 fever have I haven't filled it up yet?
convincor253 09-01-2008 06:54 PM
I believe it has either a 108 or 118 gallon tank.
bob_t 09-01-2008 08:12 PM
1997 Fountain Sales Brochure says 119 gallon for a 32'. That is the oldest sales brochure I have.
nova26 09-01-2008 08:37 PM
I was wanting to ask the same question but compare a Cig Bullet to a 32Fever with 502 or same power.
