Positioing of AC/heat and generator in 47 Lightning....??
Hi, the boat I have mentioned for you has generator and AC/heat. BUT that is not been mounted for the last 6 years! I got the AC and generator on a pallet. Where is everything mounted in your boats? There is a BIG hose for air from the cabin, coming out about at the drivers seat (inside the side room). At the bulkhead far down on a starboard side there are a few screw holes... and a "hydraulic" hose wined up. Also two water hoses (now put toghether). The AC/heat unit looks to be mounted on this side of the boat, but where? And where is the fan supposed to be? There is not space for the big air-hose to go through the bulkhead into the engine compartment.
The generator should sit on the port side. The muffler is still there. It is a Kohler. It has run 26 houres in 1998, thats all.... Do I need to have the generator mounted and working to get the AC/heat to work? And by what principe does that system work on? No one has AC here, and all heaters run on diesel only. Are you satisfied with the CruisAIR system? Does it heat well...?
THANK YOU! This flagship is day by day coming to it's deserved condition. Everything above the rub rail is wet-sanded with 1500 and 2000 paper, and 3 different 3M rubbing's + wax. I remember this boat when it was brand new... It was of an exceptionel finish and luster!!!! We have put in brad new 525s and new drives aswell.
