will the imco shorty's help or not? >
Old 03-11-2009 | 11:42 PM
my 2001 32 fever with a single step runs over 100 with -2 imco's...4 blade labbed Bravo 1's and 1.36 gear ratio. Comes out of the hole easily with tabs down. I say go for it! It works great on mine.
cyberuss is offline
Old 03-14-2009 | 10:11 AM
I have a 35 fountain with imco 2'' 1.5 and 675 hp efi Ron sporl built and mark at precision marine maped and dino. Have had no problems>
I have had every hydo prop on that boat u can think of
runs rite at 100
The boat is at fountain factory as we speek getting a windshield installed and some other goddies.
Brian at Fountain said one of my biggest problems with getting on plain is I have 15'' diam. props and I need 15.5 or 15 5/8 (5) blade to get on plane and remove the 1'' spacers. He recs. max 5 blade props
I am going back In several weeks to spend a week trying to get this 102 or 105 mph bryan said we could get out of the boat and improve getting on plain.
It may take a little while because I am finially getting married after being a 48 year old bachlor. She might slow me down a little.
After my funeral is over I will let you know what happes in washington NC
gnorthga is offline
Old 03-14-2009 | 06:14 PM
Originally Posted by gnorthga
..... Brian at Fountain said one of my biggest problems with getting on plain is I have 15'' diam. props and I need 15.5 or 15 5/8 (5) blade to get on plane and remove the 1'' spacers. He recs. max 5 blade props
Do you know what your "X" dimension is?
I tried some 15 5/8's Maxes on my '06 35 Lightning last spring and the on plane was marginal.
Please keep us posted on how you make out at Fountain, would be interesting.
RaggedEdge is offline
Old 03-14-2009 | 07:19 PM
Cyberuss,
Where do you have your tabs set when running that fast? On my 2000 anytime I raise them up past 3 the boat wants to chime walk bad, even when only going 70.
Wildman_grafix is offline
Old 03-14-2009 | 09:26 PM
Little over 19 I have 6 blabe hydo 15x32 and dam hard to get up but runs almost 100
gnorthga is offline
Old 03-15-2009 | 07:00 AM
Cyberuss,
Once I put shorties with nose cones that stoped on my 35 but I could not get on plain so I had to install a 1'' spacer to let us get on plain
gnorthga is offline
Old 03-15-2009 | 07:27 AM
Question
My boat is set up with a 19" X with a 34" center on the engines. Those numbers seem to be the norm for any '06's I have seen and most '05's as well.
Is the 19 on yours after the -2" drives and the 1" spacer are figured in? Or is it the factory std bravo dimension making your actual X higher?
Old 03-15-2009 | 12:53 PM
After the 2'' and with the spacer and what does 34'' center on the motors and how do I find out what mine is.
gnorthga is offline
Old 03-15-2009 | 06:42 PM
So essentially your effective X is the same as mine, if I'm following what you're saying.
The center deal is the distance from the center of one engine to the other. Easy to measure, go to the transom and find a point on one transom assembly and measure to the exact same point on the other. Or, call Fountain with your serial number and get your perf report, it is right on there. I don't think the center line effects the boat that much, although the closer to the keel center line the weight is the better the boat will handle, ie. the advantage of staggered set ups.
Be real interested to see how you make out with Brian @ Fountain and what he comes up with for you. I would think that with your HP you should be over 100. I've seen as much as 94 with some 5 blades on my 525 boat.
Old 03-15-2009 | 08:47 PM
I will keep you posted> You know if brian can get the spacer out and get that boat on plane with 5 blade 15.5x33 man will that boat fly. It dosent chime walk at all now. I can turn 32x15 6 blades 5500 rpms now.
gnorthga is offline
