-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   27/525 (https://www.offshoreonly.com/forums/fountain/202751-27-525-a.html)
27Fountain 02-05-2009 07:25 PM
27/525
Does any one have a 27 with a 525 in it. If so what speeds does it run and what prop are you running.
BAJA WILL 02-05-2009 08:27 PM
My old boat was a 2001 27 w/500efi GPS 74, but had to have it maxed out 5350rpms 25 Hydro RH , sometimes used a 26 Hydro RH but it took longer to plane.
I don't think many 27's were built with a 525efi, I know their are some with 525sc floating around, they got around 78mph
Hope this helps
apppedigree 02-05-2009 10:35 PM
Usually 27's dont like hydro props. Try a bravo 26 or a cut down 28.
Hydro props are harder to plane with. My old 27 was a mule to get on plane with a hydro prop.
mcprodesign 02-05-2009 10:39 PM
I ran a 27 Hydro.. It was ok till the big air buble around it wouln't go away unless I stopped. And I couldn't turn too sharp or It would cavatate. We run a 28 B1 .. you should try a 26 B1..
Chad
BAJA WILL 02-06-2009 10:30 AM
You are right but the Hydro's are a little faster:ernaehrung004:
Apple a day 02-06-2009 11:05 AM
I have a 27 with 454 385HP w/ vortech SC 3.5# boost runs mid 70s with stretched 26P bravo. For sale by the way.
