Powder coated rail touch up
Ok, I have searched the forum for an answer to no avail. My rails are starting to show some wear and some of the powder coat is coming off. Does anyone have a decent solution to this problem that does not involve rail removal? I have searched about for touch-up paint, etc., but I know powder coat ain't paint. Anyone? Thanks!!!
seaweasel i've got the same problem most of all the powder coating has came off on my rails, ive really just been tryin to figure out how to get it all removed, its comes off in flakes but its still a pain tryin to get it all off
I stripped the PC off every rail, grab handle and the seat base frames and polished them. Was a long job. The PC always looked dirty to me and had a few chips from the snaps. Looks so much better now.
Touch up with paint is a temp fix. Depends on what type of results you are after/willing to settle for.
Sorry, but they'll have to come off if you want the PC off. Not really hard to remove, just takes some time. The polishing was a job though. After I stripped them, I then used sand paper to sand them smooth. They appeared to have a glass bead texture to them. I assumed for the PC to stick?? Once I got them sanded good and smooth with a fair shine, hit them with a couple different buffing wheels and polishing sticks. I'm sure a pro would be able to polish in 1/2 the time it took me.
I soaked mine in a narrow tray filled with acetone. Let 'r soak a couple minutes, the PC'ing just bubbled up and peeled off.
SW,
I have a few nicks on my windshield trim and Shogren suggested trying Krylon Gloss White for minor touchup. I have a can but haven't tried it yet.
Another member painted a 38 or 42 last year and posted pix on the board. They sanded and painted the rub rail and wind screen frame in place and it looked pretty good.
No real short cuts I guess
Lacquer thinner will also remove powder coat. I have stripped powder coated items and painted with base/clear. This allows you to match graphic colors easily. This has actually lasted longer than the original powdercoat.
