47 With triples overheating >
Old 03-22-2009 | 06:40 AM
Question 47 With triples overheating
I took my Fountain out yesterday for a "shake-down cruise" after 4 months of winter storage. The motors started fine but after 15 minutes all three overheated. I let them cool but it happened again. I then lost water pressure in all three. I can't believe all three lost pumps simultaneously. Anyone have this happen?
pookie is offline
Old 03-22-2009 | 08:19 AM
FeverMike's Avatar
rotten impellers.
FeverMike is offline
Old 03-22-2009 | 08:23 AM
jeff32's Avatar
hard to believe but I'd also look at impeller... maybe you could have sucked sand when launching / docking the boat just before your shake down?
jeff32 is offline
Old 03-22-2009 | 12:41 PM
thanks. There was some silt in the water after I launched. I'll check the impellers.
pookie is offline
Old 03-22-2009 | 07:28 PM
make sure when u change the impellers to change the housing to because when it goes bad it sometime groves out the impeller houseing
BoatBoy 1 is offline
Old 03-22-2009 | 08:33 PM
That wasn't you up at North Point Marina was it?
Anyway, if you winterized it with the pink stuff that has alcohol in it you might have did in the impellers a bit...how old are they? and of course that sand might have helped too.
Back4More is offline
Old 03-23-2009 | 11:06 AM
BAJA WILL's Avatar
Registered User
Lost water pressure/over heating, water impeller. All three at same time??? I would call who ever did your winterizing?? Maybe they used something that disolved the impellers?? Just an idea
All that being said when was the last time you replaced the impellers??
BAJA WILL is offline
Old 03-23-2009 | 03:56 PM
It was me at North Point. I replaced the impellers last year. They really weren't that bad but I replaced all three and the housings in the middle of the season before a long trip and they worked fine. I didn't use the pink stuff. I also kept the building at 60 degrees all winter and never lost heat.
pookie is offline
Old 03-23-2009 | 05:42 PM
Also, check those"plumber faucets" that switch the flow of water when you winterize. MIne got stuck partially closed, and the same thing occurred as you mentioned... overheating in no time. Tyler Crockett figured it out: He hooked the water up to the boat like normal, but no water was then flowing out the exhaust. He dismantled the faucet, reset it, and good as new afterwards. Three impellers sounds unbelievable.
Carder
Carder is offline
Old 03-23-2009 | 05:45 PM
jeff32's Avatar
that is a good point... also happened to me with a fresh water flush system... some ball valve got stuck same problem, we took all these hoses out of boat and problem was fixed...
jeff32 is offline
