Water Faucet pump >
Water Faucet pump
Water Faucet pump
Old 04-08-2009 | 04:45 PM
dykstra's Avatar
Default Water Faucet pump
Anybody know the part number for a water faucet pump on a 1997 29 Fever. Boat is in storage, so I can't just look. Any help would be appreciated.
dykstra is offline
Old 04-09-2009 | 10:08 AM
Hey i have a 02 sitting in the drive way, i will take a look at it and get back to ASAP, i would think it would be the same.
Fever575 is offline
Old 04-10-2009 | 12:10 AM
dykstra's Avatar
Thanks man.
dykstra is offline
Old 04-10-2009 | 09:17 AM
Ok here you go the brand name is a "Sure Flo"
Model #2088-723-244
Good luck
Fever575 is offline
Old 04-10-2009 | 12:29 PM
dykstra's Avatar
Thank you very much! Love this forum! Dave
dykstra is offline
Old 04-10-2009 | 01:59 PM
Your welcome and DIDDO!
Fever575 is offline
Old 04-10-2009 | 04:00 PM
When I replaced one on one of my previous boats I couldn't get the same model number (discontinued) but I got one with close to the same flow rate. Keep the bracket from your old one as, from what I found, the bracket hole pattern had changed, and I simply installed my old bracket on the new pump and all was well.
Also, before you go buy a new pump, sometimes the bearings on the motor shaft at the pump end get some rust in them, and just need to be broke free and a small amount of lube applied (wd-40, or Tri-Flow, or something like that). The pump is quite simple to disassemble and reassemble - would try that first, as it may save you ~ $100 dollars (I now have a spare used pump that works just fine).
Bob
bob_t is offline
Old 04-11-2009 | 07:28 AM
bajarick's Avatar
Ive seen them at west marine.
bajarick is offline
