98 42 Side By Side >
98 42 Side By Side
98 42 Side By Side
Old 05-19-2009 | 01:13 PM
johnnyboatman's Avatar
Default 98 42 Side By Side
What Speeds And What Power And What Props Do You Run?
johnnyboatman is offline
Old 05-19-2009 | 02:44 PM
blownincome's Avatar
John what setup are you running?? drive ratio and Xrs or B1s thanks
Bob
blownincome is offline
Old 05-19-2009 | 05:28 PM
1.30bmaxs 28bravos
Old 05-19-2009 | 07:01 PM
later's Avatar
98 500hps 28 bravo one's 1.5's. light fuel load and cool temps 80-81 normal conditions 78-80, classic deck. love the extra space in cockpit.
later
later is offline
Old 05-19-2009 | 07:32 PM
later
Thats the setup! With 1:3 s you could push 30 5 blades I bet
Old 05-19-2009 | 09:58 PM
i ran 5000rpm spinning the 28s showing 90 on the gps, i pulled 5700 in my other boat cant figure out why i cant get it to turn more rpms, it planes instantly. the cresent lowers on the bmaxs have a rough casting im going to smooth those and check the carbs to make sure they are opening all the way.
seems like it ran flat, not nose high like the one in your pic.
Old 05-19-2009 | 10:13 PM
Your almost where im at, 5300/28's/91 i would think you should be about 5-7 mph faster.
are you spinning in or out?
Back4More is offline
Old 05-20-2009 | 09:04 AM
Spiining In, Im Down 700rpm I Think The Lower Skegs Are Draging Hard They Appear To Be Real Thick Compared To A Reg Bravo Lower.
Old 05-25-2009 | 06:51 PM
Transom pics?
