2000 32 fever starting issues >
Old 05-20-2009 | 08:53 PM
266ltd's Avatar
Default 2000 32 fever starting issues
i posted a thread in general Q&A but have not got a response. i installed a new slave selinoid for my starboard motor, it would just click, so before i repl. i jumped the 2 big wires and cranked right over. as i was repl. it i touched the wench i was using to the 5/16 bolt holing the cathode on and sparks. i know i should have tuned the power off, but i didnt. so now i have nothing, turn the key no gauges, no beeps, i get nothing when i jumper across the 2 big term. on the slave selinoid. i checked all visible breakers and fuses all ok i even jumperd around the motor breakers just incase one was bad. is there a fuse or breaker somwere that i cant find? help please!!
266ltd is offline
Old 05-21-2009 | 06:11 AM
blownincome's Avatar
Folow the solinoid wire you will find a fuesable link (small red box with a blackbutton) (looking) Im pretty sure this is your issue
Look at link http://www.boaterslandfishing.com/qs2335-10.html
See # 8
blownincome is offline
Old 05-21-2009 | 08:49 AM
266ltd's Avatar
wat type of fuse is it? will i need to repl. it or can it be reset. it also looks like it should b located on the starter?
266ltd is offline
Old 05-21-2009 | 12:01 PM
bcfountain's Avatar
Registered User
Default fuse
the fuse on the starter is a80amp i think.they are not cheap either.guy working on one of my boats did the same thing.and i had to buy another fuse.hope this helps.
bcfountain is offline
Old 05-22-2009 | 07:32 PM
You will need to replace it it is a fuse not a breaker
