How fast is your boat. Hammer 34? I think 80 still isn't that bad ya it isn't no where never as fast as many and may be on the slower side as far as go fast but still faster than most boats on the market. And it's still a FOUNTAIN !! witch makes it better by default.
I have an "05 -- 42' Ex with 525's. My buddy has an '05 -- 35' Ex with the same engines. I have the newer double step bottom and he has a single step. Both are the staggered set up. He runs 88mph in perfect water and I run 85 in the same. Difference is that I can run 80 plus in most any water and he has to slow down when it gets rough. Both excellent boats. An '05 -- 35' Lightning with staggered 525's with the twin step hull will run in the low 90's. He gets a little better gas mileage. I trailer mine all the time with no problems. No substitute for HP, length, and weight. Always get the bigger boat if you can.
Originally Posted by Dirty Affair
(Post 2934950)
(Post 2934950)
You will outgrow the 35. Go with the 42 staggered. It is just as efficient, has way more room and rides like a caddy.
Originally Posted by aTX427
(Post 2935843)
I have a 38 and love it, the 35s are OK unless the water is sloppy. Raced a 35 in New York and could not keep it wide open, ran a 38 and kept it WOT all during the race. Both had 502-500s. 35 ran 103 but could not keep it there, 38 ran 95-98 and averaged more during the race and finished higher. Buy a 38 or 42. Roger
| All times are GMT -5. The time now is 09:50 PM. |
