Reggie got 74mph on my boat, and OK bear with me, I measured the X dim last night,(Ithink correctly). I came up with 17" from notch in hull to bottom of drive.:rolleyes:
WIll |
FEVER MIKE,
If I ever decide to put my boat in the salt I will be more than happy to show you what the back of a 27 looks like from a DISTANCE!:p |
Mike what's salt worth in speed compared to fresh generally speaking?:confused:
FeverMike
Thanks for the X dim info, When you say center of drive shaft, you mean the actual center like where the lower meets the top, their is like a flap of metal that goes around where they connect? I will remeasure, going that route. Will:cool: |
Does anyone know If the 32 is faster than the 35 with say 650-700 hp? You would think with the change in power to weight ratio the top speed numbers would change.
Also I am looking for a 32' stepped Fountain but I need to sell my 1992 27 ft with 700hp first |
OK, lets measure this bad boy again, Thanks Fever Mike, I think I got it this time.;)
WILL |
| All times are GMT -5. The time now is 12:12 AM. |
