-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Older 36-38 Fever speeds (https://www.offshoreonly.com/forums/fountain/220757-older-36-38-fever-speeds.html)
MDGperformance 12-03-2009 08:28 PM
Originally Posted by MILD THUNDER (Post 2999191)
Curious, what kind of speeds should a straight bottom 38 fever run with a pair of 620HP motors/#3 SSM setup?? 75?80?85?
My guess mid 70,speedmaster3 take a lot of power and are usually run deep in water,a lot of factors hull weight,drive height,prop choice,the main problem with running 3 are getting the height right and prop right,they are very reliable drives at the 625hp level
10x 12-04-2009 03:52 PM
Originally Posted by MILD THUNDER (Post 3000173)
Frank, did you ever run yours with the #4's and no boxes or did you always have them?
Joe,
Mine came from the factory with the boxes on it. Only time I had them off was to paint em.
