Extension box on Fever 27 - Bravo drive >
Old 03-03-2010 | 05:36 PM
Originally Posted by JimV
I do have a bravo drive. I turn a 30 pitch 4b1 about 6000 to 6100 rpm. The box was worth speed and better handling. With a step bottom I think a shortie lower would benifet as well. I tried the 2" shortie with the box on mine but I don't think it liked the nose cone. I believe it works the best at neutral or slightly positive trim where step bottoms work.
My motor made 780 hp maybe more coming for this year I don't know yet. What you may notice is a loss in cruise speed If you raise the drive higher than where it is now. A five blade will help but it will tax the drive
Good luck, Jim
What do you think the box alone is worth? And what do they typically run in price?
SDFever is offline
Old 03-04-2010 | 07:24 AM
JimV's Avatar
I would have to guess 3-4 mph. I made more than one change at a time. You can find them used for under 2k.
JimV is offline
Old 03-04-2010 | 11:31 AM
That's my issue is that I changed too many things at once also so there's no way to tell.
You must have the fastest 27 out there.
SDFever is offline
Old 03-06-2010 | 05:17 PM
JimV's Avatar
Thanks!
JimV is offline
