throttle cable sticking >
Old 03-14-2010 | 07:27 PM
Default throttle cable sticking
42 07 lighting throttle cable stiff and sticking
Just seams like to new of a boat to be doing that
guess I just need to replace the cable?
big job
gnorthga is offline
Old 03-14-2010 | 10:40 PM
Have you checked the tension adjuster on the throttles yet? I had one that worked a little stiff when I first got this one, backed it off and a little lube, been fine since.
RaggedEdge is offline
Old 03-15-2010 | 05:40 AM
Beak Boater's Avatar
Charter Member # 545
big job
We broke a shift cable on an 07 boat last year, while backing into a slip at a poker run. The length is stamped on the outside near the end of the cable. It really wasnt that big a job in our case. Took maybe an hour.
Beak Boater is offline
Old 03-15-2010 | 09:46 AM
Thanks! Ragged
I have had the the shifter in a million pieces
I am pretty sure it is the cable
gnorthga is offline
Old 03-15-2010 | 09:48 AM
Talking
Thank you! I will order one today
Fountain must have got a bad run on cables that year
Lol
gnorthga is offline
Old 03-15-2010 | 11:54 AM
Thanks! Ragged
One other thing to check is the routing of the cable to make sure there are not any tight bends. I did play with that a little on mine where they ran around the stbd side in the bilge and across the transom to the engines. Might check for the same under the dash.
