Moisture in the storage step entering the cabin >
Old 03-29-2010 | 02:57 PM
My 27 does the same thing, kept on a lift, and when there is water in the bilge, I get a little in front under the step as well. The bow is a bit higher than the stern, but that is a low spot in the keel. When the bilge is dry, I shop vac the area under the cabin step and it stays dry until my main bilge gets any water in it. I have just accepted it. Water can leak in from the base of the windshield, onto the floor, down the rear drains and into the bilge...that's how it gets there while on the trailer.
Also have to go swimming, or launch a dinghy to get to my drain plugs.... being that I pull the boat in bow first due to water depth.
Scooter B is offline
Old 03-29-2010 | 05:42 PM
Bad Girl's Avatar
Default cleats
the side cleats may not have cups on them either . this will put water in the front under the cockpit floor. The lack of cups made my side compartments wet when it rained.
hope it helps!
47 Lightning SE
Bad Girl is offline
Old 06-03-2010 | 06:34 PM
no way is your 32 bilge 100% dry unless you glassed in the rear vent holes which flood w/ the smallest waves while anchored!
grapeape93 is offline
Old 06-04-2010 | 08:04 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
My 32's bilge is 100% dry. Not a drop.
I had to reseal the rubrail to get there though. I never had water get in throught the vent tubes.
US1 Fountain is offline
Old 06-04-2010 | 06:30 PM
I resealed the transom as well with 5200
Old 06-04-2010 | 07:55 PM
I was really shocked @ what was underneath my rubrail on the transom.... You could even make out where someone @ the factory had wrote what looks like "sloppy" on the starboard corner I tried some sealant but I didn't do a very good job, I'm gonna try it again this weekend....
jmoore1225 is offline
Old 06-04-2010 | 11:48 PM
Water in the step area in a step bottom boat is just a given. The chit is gravity based by nature, and will seek the lowest point, mother nature at work.
The funny thing here is that when I came on here for a look see the new OSO add machine pulled up a link to a basement waterproofer!
RaggedEdge is offline
Old 06-05-2010 | 08:09 AM
Bad Girl's Avatar
Default cockpit floor drains
do they drain into the forward compartment on a 47?? while rinsing it out it did not go into the bilge or at least directly.
Boat was on trailer with the nose way up since I was washing it out.
47 Lightning SE
Bad Girl is offline
Old 06-12-2010 | 07:46 AM
If you use your built in cooler try pouring water in the cooler and look under the step. My 98 32 fever cooler drains there but the pump wont empty it completely.
SPEEDFREEK is offline
Old 06-12-2010 | 11:59 AM
BZ's Avatar
BZ
I have owned X3 Fountains and they all did the same thing???? so I just bought a good shop vac.......
BZ is offline
