Removing Dash Plate??
Is it true that you can remove the entire gauge/dash cluster by simply unplugging plugs? Is there an actual wiring harness that allow wires to be disconnected under the dash? Oh and this is in a 96 35' Lightning.
dash
Its pretty easy alittle then harness'. 4 indicator cables, two throttle, two shift cables, Two engine harness' 1 trim harness,water psi hoses, speedo hose, and depth gauge. from the factory everything has plugs or very easily attached. hope that helped.
All the wiring on my '99 just unplugged. Had several trailer type of plug connectors. Other than the shifter and indicator cables.
Are the plugs just bundled up under the dash? What was the easiest way to access them?
Originally Posted by Rcolter
(Post 3108790)
| All times are GMT -5. The time now is 06:59 AM. |
