msd box
Old 05-17-2010 | 07:35 AM
Default msd box
well i have to go to msds so i was curious were to mount the boxes. transom looks out of the question.any sugestions and pics . thanks
brians fever is offline
Old 05-17-2010 | 11:52 AM
Throttle Fever's Avatar
Mounted mine in the recess above the transom. Made some aluminium plates 16"x 10" and mounted box, coil and rev box on it then gave it a slight bend. Broke the edges of the plate for strenght. Do not have any pic's, but might be able to get some (if the the rain stops) tonite. Pete
Throttle Fever is offline
Old 05-17-2010 | 01:06 PM
10x's Avatar
10x
10x
Mounted mine on the ledge that's about even with the rub rail across the transom. A few pics.
Attached Thumbnails msd box-100_6296.jpg   msd box-100_6299.jpg   msd box-572-fi-4.jpg
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
10x is offline
Old 05-17-2010 | 04:58 PM
nice setup 10x but i dont have that ledge on mine.in fact there is no room behind the engines. throtle did you mount to the transom or the front lip.
Old 05-17-2010 | 05:16 PM
Sorry Brian to the transom at the rubrail line like 10x. How about the side? Pete
Old 05-17-2010 | 05:27 PM
thinking about putting them on the stringers that run next to the batery boxes
Old 06-16-2010 | 09:22 AM
I know this thread is a month old, but ran into this issue last weekend. Didnt have enough room above the inner transom plates, so i fabbed up a plate. Bolted the box and rev limiter to it, then fastened it to the transom...
MILD THUNDER is offline
Old 06-24-2010 | 04:15 PM
waterbum's Avatar
Mine are mounted on an angle bracket attached to the bulkhead. Needs about 6 feet or so of wiring to reach the distributor and other stuff at the back of the engines.
waterbum is offline
