oddssey allllll the way . optima is old school . a pc925 starts my 525 no problem . I have two & also have a jammin system . Best thing is they weigh only 26 lbs each . I also had these in my eliminator & they worked perfect . they are so small like 7x7x6
I have had very good luck with the WestMarine AGM batteries.
Well, I think it's time for new batts. I'm charging them now to confirm they'll hold a charge or are dying a slow death. Going on 5+ years I think the WalMart batts are done. W/a single 509, I run two 800CCA cranking and two deep cycle for stereo. The two cranking are wired together and the two deep cycle are together and the entire set is split w/a perko. If found group 27 batteries:
Costco $85 (1yr free replacement) Autozone $100+ (but didn't even have grp27) WalMart $88 (3yr free replacement) I've searched the threads and still think the WalMarts are the best option based on price and warranty.....thoughts/opinions? |
I had two Optimas, 6 months old, in my Excursion, one shorted out took out my alternator. Got rid of them both..
never again. Interstate has been problem free so far.. |
Optima are overpriced garbage made in Mexico.
ok, thanks. I know what not to buy!
I did a ton of research on this recently before buying.
Ended up going from Group 27 to Group 31 and building my own battery boxes because I couldn't find a decent marine style battery box for the larger battery. The West Marine AGM's are very good, lots of good reviews, made by Deka. I liked the huge CCA for cranking big blocks. Found them over $100 each cheaper at a local battery supply place than at West Marine. Paid about $200 each. Exact same battery made by Deka without the West Marine sticker. Probably went overkill, but set it and forget it. I'd sooner that than be floating without power or working on it. Key is to figure out what type of battery you need and use it the way its supposed to be used and was designed for. Starting battery, deep cycle, one of each, or multi purpose (compromise on both). |
Two AC Delco maint free car batterys......take them out and store them in the house all winter....4th season with them
Hello all,
Why isn't anyone here in the performance boating biz, talking about using the lightweight lithium batteries ??? A group 27 SLA weighs 54 lbs Do fast boats NEED the extra weight ?? Why not use a lighter battery and add a couple cases of beverges..??? somebody educate me on this.. |
Originally Posted by battman
(Post 3491349)
Hello all,
Why isn't anyone here in the performance boating biz, talking about using the lightweight lithium batteries ??? A group 27 SLA weighs 54 lbs Do fast boats NEED the extra weight ?? Why not use a lighter battery and add a couple cases of beverges..??? somebody educate me on this.. I have energizers from sams club group 27 cost me 70 bucks. ran all summer without a charge so far. Thing with batteries is just like oil there are really only a few manufactures. But I would agree Optima is overpriced. |
| All times are GMT -5. The time now is 04:01 AM. |
