38 Fever Nav light bulbs >
Old 11-26-2010 | 10:27 AM
Default 38 Fever Nav light bulbs
Any tips on changing the nav light bulbs on a 1990 38? looks like i have to remove some interior trim to access them?
MILD THUNDER is offline
Old 11-26-2010 | 10:33 AM
On mine use unscrew the light itself, from the deck.
Wildman_grafix is offline
Old 11-26-2010 | 10:38 AM
I should have mentioned i have the ones on the port side/starboard side. The cat eye style. Tried to unscrew them from the outside, but screws just turn. I am guessing there is a nut on the inside??
Old 11-26-2010 | 11:14 AM
I have the same boat. Go inside v-berth and remove forward panel that is @ the head of the v-berth. Once your in the bow then you can pop out the lights from the fixture. PS - Check for power - may be a bad connection.
poolshrk is offline
Old 11-26-2010 | 01:30 PM
Wear long sleeves fiberglass is a *****
jmoore1225 is offline
Old 11-26-2010 | 05:47 PM
blownincome's Avatar
remove the Mirror and you are in! also while you are in there make sure your bow cleat does not leak if so unscrew it and reseal
blownincome is offline
Old 11-26-2010 | 07:36 PM
Awesome! Mine had a loose connection or dirty, would come on if I karate chopped it.....
Old 11-27-2010 | 05:44 AM
My 90 lightning did the same thing! had a light amount of corrosion on it I soldered a wire to the bulb housing and grounded to to the harness direct . before i did that it kept happening even after I cleaned it !
