1997 42 fountain, will boxes help???? >
Old 02-17-2011 | 10:19 PM
obnoxus's Avatar
Charter Member #1171
Originally Posted by TunnelVision3100
. I have a problem with getting on plane. Props blow out as soon as she's about to fall over.
Its the driver !!!!!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 02-19-2011 | 09:53 AM
Bad Girl's Avatar
Default 42 with high ssm6
My 42 flatbottom planed and ran awsome with drives even with the bottom and the drives stretched out the back. Tabs were all it needed to plane.
This was the most aggressive rough water boat. Did scrub 2-3mph speed on top running 17 1/4 diameter 4 blades on 18" centers.
Running on Lake Erie I would prefer rough water setup anytime.
My 47 would be no match in 4-6 footers since there is less leverage on the nose to let it carry more evenly than tabbing it down into a wave.
I am looking to put boxes on the 47 for sure.
Ken
47 Lightning SE
Bad Girl is offline
Old 02-21-2011 | 03:09 PM
The speedmasters have always held up well for me with 800-900 hp . The 3's , 4's ,and 5's work well . Complete gimble and drive packages can be had reasonable . Now that repacement parts are available again , might be worth checking out . Rebuilds are probably no worse than a high performance bravo . I have had them last for years with few problems .
notda1 is offline
Old 02-21-2011 | 03:16 PM
I even know where to get a deal on a complete set up , if anyone is interested PM me .
notda1 is offline
Old 02-22-2011 | 06:30 PM
carney's Avatar
I have stelling boxes on my 35, they have 5 different mounting holes, mounted as high as they can go. the boat gets on plane like no other, I do think they took away a couple mph on top, like everyone said you sould use 2 inch shorties , they will get the mph back and some but I will bet it will get on plane slower. I really like them on this 35. they work great to get in the boat when in the water, puts the drives back far enough to use the drive as a ladder. multi purpose add on.
carney is offline
