-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   35 ex prop swap turn em in ? (https://www.offshoreonly.com/forums/fountain/248305-35-ex-prop-swap-turn-em.html)
Dan74 02-25-2011 09:34 AM
Boat is an older 33 executioner, now running approx 82gps and best of 85 real light, 580 hp na 509s and speedmaster 2's with 3 blade cleaver props.
Considering swaping prop rotation. Curently turning out. Have searched and seen some others get a couple of mph swaping to turn them in with more stern lift but i Dont know my x dimension but its rigged very low and whole prop swings below the keel. Would i see a gain or is it only with later models with higher x dims, any difference in kicking up a rooster tail rigged this low ?
MILD THUNDER 02-26-2011 08:05 AM
Only real way to know is try running them in, and see how the boat reacts. Normally, in provides more bow lift, and usually runs faster top speed. Downside is, handling might suffer, and docking can be a pain. Mine turn in on my straight bottom 38 with speedmasters. Docking kinda sucks.
monstaaa 03-05-2011 07:33 AM
All beams turn in.
35 fountain 03-05-2011 02:52 PM
Mine Turn in. Very little control in reverse. No fun at the dock
RaggedEdge 03-05-2011 06:49 PM
Very few boats shine around the docks with the props turning "in". It is the price you pay to have a Fountain run it's best on the water. Simply learn to compensate around the dock, turn them "in"!!! Enjoy the better handling when out on the water.
In reality, you spend hours running on the water and only a few minutes docking the boat. Man up and make the adjustment, real men can dock a boat with the props turning "in"!!!
mcprodesign 03-08-2011 01:06 AM
Real men dock a 27 single screw that will only turn one way when you back up . :lolhit: :D
Reggie 03-08-2011 05:38 PM
I hear you on the docking issue, and it's very hard to tell other boat owners that know how to back up a boat, that FOUNTAINS are hard to back up. I've found using the Port drive only sure helps me, I lift the drives to 3, and just use the port motor, works for me.
PARADISE ISLAND 03-08-2011 06:41 PM
Put the boat in the water see if it works:evilb:
monstaaa 03-08-2011 08:14 PM
Meant beaks.
monstaaa 03-08-2011 08:15 PM
pp.s I have never noticed any considerable difference.
