-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Speedo Stopped working??? (https://www.offshoreonly.com/forums/fountain/255550-speedo-stopped-working.html)
TC G 06-10-2011 08:07 AM
Took my 27 Fever out last night and the speedo wasn't working. Are there any quick things I should try to fix it before digging deeper. Any ideas would be appreciated.
techman 06-10-2011 08:46 AM
Is it a GPS model or a Pitot tube one?
carcommander 06-10-2011 09:55 AM
If its GPS the antenna is probably not working. I had to replace mine after 5 years.
mapism 06-10-2011 10:08 AM
You could have just replaced the battery instead. Impossible according to Livorsi, but then again, what do they know...? :lolhit:
Baja_342 06-10-2011 10:08 AM
And if it's pitot it's clogged. Small hole on leading edge of the outdrive. Take a small drill bit by hand to try and work it loose. Don't cram anything in there too far.
techman 06-10-2011 01:13 PM
If you have a Livorsi GPS unit, then here is the option from Livorsi:
http://www.livorsi.com/catalog/gps_antenna.htm
My antenna battery died on mine after 5 years and I chose to bypass the antenna puck and plug the speedo directly into my GPS/Chartplotter.
Good luck.
Wildman_grafix 06-10-2011 03:42 PM
Good luck.
Wow I bought a GARMAN antenna for something like $95
