Plastic cover for anchor locker drain
From west marine web site,,,,,,,,,,,,,,,,,,,, not the best reference but one.
Trailer winches are not tie downs. To prevent mishaps, use dedicated bow and stern tie downs to secure your boat on the trailer.
I run two saftey chains on the front of mine, one to control movement back, the other set to control movement foreward.
Saftey back-up in case the winch strap were to break. No need to be tight, just not a lot of excess. Should also have tie downs on both sides of the transom.
Registered User
As mentioned before, they best place to purchase the drains is from Fountain. I bought 6 or 8, they were cheap, that way when they broke, and the do break often, easy to replace. If the part is accessible grab it with a pair of needle nose pliers and just pull it out. If it is broken off smooth with the hull just push in the stub and it will fall to the bottom of the rope locker and don't worry about it. Then put the new one in with a little silicone. Easy to do.
Registered User
You can buy standard boat tie down straps, from West Marine or any boat dealer. Just go from the tie down eyes on the transom to the tie downs on the trailer, they will go right around the K-planes and just pull them tight.
X2. Just find the best route from the eyes to your trailer tie downs, easy as that.
